  "failed to set clk" and "Kernel panic"
Question asked by wei sheng on Oct 27, 2015
Latest reply on Oct 27, 2015 by igorpadykov
we use a board copy by freescale sabre-sdl board,when boot the kernel,I meet the error below,I have try to chanded pll2_pfd2_594m to pll2_pfd2_396m or 352, or set maxcpus=1 (nosmp) in kernel (by the way ,how to set the two args correctery by detail? I use setenv nosmp 0)args, I am very confused !someone please help me out! thanks !
U-Boot 2015.04 (Oct 23 2015 - 15:25:09)
CPU:   Freescale i.MX6SOLO rev1.2 at 792 MHz
CPU:   Temperature 39 C
Reset cause: POR
Board: MX6-SabreSD
I2C:   ready
DRAM:  1 GiB
PMIC:  PFUZE100 ID=0x10
MMC:   MMC/SD: Reset never completed.
voltage not supported by controller
FSL_SDHC: 0
*** Warning - bad CRC, using default environment
No panel detected: default to QIMEI-SWVGA
Display: QIMEI-SWVGA (800x600)
In:    serial
Out:   serial
Err:   serial
check_and_clean: reg 0, flag_set 0
Fastboot: Normal
flash target is MMC:0
Net:   FEC [PRIME]
Error: FEC address not set.
Normal Boot
Hit any key to stop autoboot:  0
booti mmc0
kernel   @ 10808000 (6819528)
ramdisk  @ 11800000 (725616)
fdt      @ 11700000 (32597)
kernel cmdline:
        use boot.img command line:
        console=ttymxc0,115200 init=/init rw video=mxcfb0 vmalloc=400M androidboot.serialno=1822a9d4df668b47
switch to ldo_bypass mode!
   Using Device Tree in place at 11700000, end 1170af54
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Initializing cgroup subsys cpuacct
Linux version 3.10.53-88204-g4f0dd92-dirty (weiss@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Oct 27 17:36:57 CST 2015
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX6 Quad/DualLite (Device Tree), model: Freescale i.MX6 DualLite SABRE Smart Device Board
cma: CMA: reserved 256 MiB at 3a000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @820c3000 s9728 r8192 d14848 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 259840
Kernel command line: console=ttymxc0,115200 init=/init rw video=mxcfb0 vmalloc=400M androidboot.serialno=1822a9d4df668b47
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 959MB 64MB = 1023MB total
Memory: 758744k/758744k available, 289832k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xc0800000 - 0xff000000   (1000 MB)
    lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80e7a48c   (14794 kB)
      .init : 0x80e7b000 - 0x80ed0600   ( 342 kB)
      .data : 0x80ed2000 - 0x80f56000   ( 528 kB)
       .bss : 0x80f56000 - 0x80feacf8   ( 596 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32050000, Cache size: 524288 B
failed to set parent of clk gpu3d_shader_sel to pll2_pfd2_396m: -22
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
CPU identified as i.MX6DL, silicon rev 1.2
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
Security Framework initialized
SELinux:  Initializing.
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys freezer
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x807e23e8 - 0x807e2440
Brought up 1 CPUs
SMP: Total of 1 processors activated (1581.05 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
DMA: preallocated 256 KiB pool for atomic coherent allocations
Use WDOG2 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1100 mV
vdd3p0: 2800 <--> 3150 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2400 mV
vddarm: 725 <--> 1450 mV
vddpu: 725 <--> 1450 mV
vddsoc: 725 <--> 1450 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6dl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
mxs-dma 110000.dma-apbh: initialized
usb_otg_vbus: 5000 mV
usb_h1_vbus: 5000 mV
mipi_dsi_pwr_on: no parameters
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
imx-gpc 20dc000.gpc: failed to get clk!
imx-gpc: probe of 20dc000.gpc failed with error -2
Switching to clocksource mxc_timer1
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 708K (81800000 - 818b1000)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
of_clk_src_onecell_get: invalid clock index 245
ERROR: could not get clock /soc/busfreq:axi_alt_sel(10)
imx6_busfreq busfreq.13: busfreq_probe: failed to get axi_alt_sel_clk
imx6_busfreq: probe of busfreq.13 failed with error -2
Bus freq driver module loaded
futex hash table entries: 256 (order: 2, 16384 bytes)
audit: initializing netlink socket (disabled)
type=2000 audit(0.270:1): initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
NTFS driver 2.1.30 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 1995
io scheduler noop registered
imx-weim 21b8000.weim: WEIM driver registered.
pwm-backlight backlight.18: invalid default brightness level: 16, using 7
mxc_mipi_dsi 21e0000.mipi: failed to reset: -2
mxc_mipi_dsi: probe of 21e0000.mipi failed with error -2
MIPI DSI driver module loaded
mxc_sdc_fb fb.16: registered mxc display driver lcd
Console: switching to colour frame buffer device 100x30
imx_epdc_fb 20f4000.epdc: can't get/select pinctrl
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: initialized
imx-sdma 20ec000.sdma: loaded firmware 1.1
pfuze100-regulator 1-0008: Full lay: 2, Metal lay: 1
pfuze100-regulator 1-0008: FAB: 0, FIN: 0
pfuze100-regulator 1-0008: pfuze100 found.
SW1AB: 300 <--> 1875 mV at 1175 mV
SW1C: 300 <--> 1875 mV at 1175 mV
SW2: 800 <--> 3300 mV at 3300 mV
SW3A: 400 <--> 1975 mV at 1500 mV
SW3B: 400 <--> 1975 mV at 1500 mV
SW4: 800 <--> 3300 mV at 3150 mV
SWBST: 5000 <--> 5150 mV at 5000 mV
VSNVS: 1000 <--> 3000 mV at 3000 mV
VREFDDR: 750 mV
VGEN1: 800 <--> 1550 mV at 1500 mV
VGEN2: 800 <--> 1550 mV at 1500 mV
VGEN3: 1800 <--> 3300 mV at 2800 mV
VGEN4: 1800 <--> 3300 mV at 1800 mV
VGEN5: 1800 <--> 3300 mV at 3000 mV
VGEN6: 1800 <--> 3300 mV at 3300 mV
Serial: IMX driver
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
of_dma_request_slave_channel: dma-names property missing or empty
spi_imx 2008000.ecspi: cannot get the TX DMA channel!
spi_imx 2008000.ecspi: dma setup error,use pio instead
spi_imx 2008000.ecspi: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
CAN device driver interface
fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unregistered net_device): Using random MAC address: f6:20:f9:fd:78:7d
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.10.53-88204-g4f0dd92-dirty ehci_hcd
usb usb1: SerialNumber: ci_hdrc.1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
usbcore: registered new interface driver wacom
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
imx2-wdt 20c0000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver btusb
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc1: no vqmmc regulator found
mmc1: no vmmc regulator found
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
mmc3: no vqmmc regulator found
mmc3: no vmmc regulator found
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mmc1: host does not support reading read-only switch. assuming write-enable.
mxc_asrc 2034000.asrc: failed to get asrck clock
mxc_asrc: probe of 2034000.asrc failed with error -2
mxc_vpu 2040000.vpu: failed to get vpu power
of_clk_src_onecell_get: invalid clock index 248
mmc1: new high speed SDHC card at address e624
ERROR: could not get clock /soc/aips-bus@02100000/caam@2100000:caam_ipg(2)
mmcblk1: mmc1:e624 SU08G 7.40 GiB
caam 2100000.caam: can't identify CAAM ipg clk: -2
Unable to handle kernel NULL pointer dereference at virtual address 00000004
pgd = 80004000
[00000004] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.53-88204-g4f0dd92-dirty #1
task: bc06c000 ti: bc06a000 task.ti: bc06a000
PC is at caam_sm_startup+0x68/0x2a4
LR is at caam_sm_startup+0x68/0x2a4
pc : [<805d9468>]    lr : [<805d9468>]    psr: a0000113
sp : bc06bef8  ip : 00000073  fp : 00000000
r10: 0000016f  r9 : 80ecd680  r8 : bc476210
r7 : 80eaf6b0  r6 : bc0e0610  r5 : 00000000  r4 : bc40f780
r3 : bc48ed80  r2 : 00000000  r1 : bc40f780  r0 : 00000000
Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 1000404a  DAC: 00000015
PC: 0x805d93e8:
93e8  e1a0a000 eaffff65 80ee1e44 80fb27c0 80ee3af8 80dd9680 e92d4ff8 e2806010
9408  e1a00006 ebf761f2 e59f327c e30810d0 e1a05000 e5930008 ebec01f5 e2504000
9428  0a000094 e3a00000 e59f2260 e1a01000 e5846000 eb00ae0c e59f1254 e1a02006
9448  eb00b895 e3500000 0a000086 e2808010 e5840008 e1a01004 e1a00008 ebf76205
9468  e5858004 e5953010 e5932fd8 f57ff04f e7e53852 e2833001 e5843044 e5953010
9488  e5932fd8 f57ff04f e7e33652 e2833001 e5843048 e5953010 e5932fd8 f57ff04f
94a8  e202303f e2833001 e584304c e5953010 e5932fdc f57ff04f e7e23852 e3a02b01
94c8  e1a03312 e5843050 e3a03080 e5843054 e5953008 e5930000 e2800010 e5840004
LR: 0x805d93e8:
SP: 0xbc06be78:
be78  803ae98c 807d3c9c 00000000 807e1de0 bc0e1180 807d3d6c 00000000 807e1b54
be98  bc476210 805d9468 a0000113 ffffffff bc06bee4 8000dc58 00000000 bc40f780
beb8  00000000 bc48ed80 bc40f780 00000000 bc0e0610 80eaf6b0 bc476210 80ecd680
bed8  0000016f 00000000 00000073 bc06bef8 805d9468 805d9468 a0000113 ffffffff
bef8  80812a00 80f56000 bc06a000 80ec2250 80eaf6b0 00000000 80ecd680 0000016f
bf18  00000000 80eaf6f4 00000000 800086ec 00000001 00000003 00000000 ffffffed
bf38  820c0dff 80049394 80db4f38 80e388ec 00000006 00000006 80ee922c 80ec2270
bf58  00000006 80ec2250 80f56000 80e7b428 80ecd680 0000016f 00000000 80e7bb8c
R1: 0xbc40f700:
f700  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
f720  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
f740  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
f760  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
f780  bc0e0610 00000000 bc476200 00000000 00000000 00000000 00000000 00000000
f7a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
f7c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
f7e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
R3: 0xbc48ed00:
ed00  bc478840 bc044140 bc48ea04 bc04414c bc044140 80f03844 bc4788c0 00000001
ed20  00000007 00000000 bc48ed28 bc48ed28 00000000 00000000 bc02f670 bc02f674
ed40  bc48ea3c 00000001 00000000 80f36f28 00000000 00000000 00000000 00000000
ed60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ed80  00000000 bc48ed84 bc48ed84 803ae98c 803ae9d4 bc0e1180 bc0e1184 bc0e1184
eda0  00000001 00000000 00000000 00000000 00000000 bc02f65c bc02f660 bc4565b8
edc0  00000001 bc48edc4 bc48edc4 bc40f780 bc476210 00000000 00000000 00000000
ede0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
R4: 0xbc40f700:
R6: 0xbc0e0590:
0590  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
05b0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
05d0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
05f0  00000000 00000000 00000000 00000000 bc0e2340 ffffffff 00000000 00000000
0610  bc0e0410 bc0e1180 bc0e2340 bc0e081c bc0e041c bc0e0418 bc0413c0 80f037a0
0630  bc0e23c0 00000009 00000007 00000000 00000000 00000001 00000000 bc0e064c
0650  bc0e064c 00000000 00000000 80f03900 00000000 00000000 00000000 00000020
0670  00030003 bc0e0874 bc0e0474 7fffffff 00010001 bc0e0684 bc0e0684 00000000
R7: 0x80eaf630:
f630  e1a00005 e3a03001 e1a02102 e12fff3c e3a03000 e1a00004 e1a01003 e58430ac
f650  e58430a8 ebe4b7fa e1a00004 e3a01001 ebe4b7f7 e1a00005 e59f1038 ebd3ff61
f670  e59f0034 e28dd008 e8bd4070 ead39687 e3e00012 e28dd008 e8bd8070 80dd9520
f690  80dd9530 80fc9590 80dd95d0 80ee3af8 80ee1e44 80fb27c0 80dd9634 80f392f0
f6b0  e3a00000 e59f2048 e1a01000 e92d4008 ebdd556b e2501000 1a000004 e59f2034
f6d0  ebdd5567 e2501000 03e00012 08bd8008 e1a00001 ebdd5e69 e3500000 0a000002
f6f0  ebdca742 e3a00000 e8bd8008 e3e00012 e8bd8008 80dd9520 80dd9530 e3a00000
f710  e59f2048 e1a01000 e92d4008 ebdd5554 e2501000 1a000004 e59f2034 ebdd5550
R8: 0xbc476190:
6190  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
61b0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
61d0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
61f0  00000000 00000000 00000000 00000000 bc478a00 ffffffff 00000000 00000000
6210  bc0e0610 bc48ed80 bc478a00 bc0413c0 bc487c74 bc0e0618 bc0413c0 80f037a0
6230  bc478a80 00000003 00000007 00000000 00000000 00000001 00000000 bc47624c
6250  bc47624c 00000000 00000000 80f03900 00000000 00000000 00000000 00000020
6270  00010001 80f03eec bc487ccc 7fffffff 00010001 bc476284 bc476284 00000000
R9: 0x80ecd600:
d600  80eae314 80eae38c 80eae3bc 80eae3e4 80eae4fc 80eae618 80eae700 80eae70c
d620  80eae718 80eae724 80eae730 80eae88c 80eae8fc 80eae908 80eae9b8 80eaea34
d640  80eaea58 80eaea70 80eaea7c 80eaec34 80eaec60 80eaec6c 80eaece4 80eaede8
d660  80eaedf4 80eaee00 80eaee48 80eaee54 80eaee78 80eaf27c 80eaf49c 80eaf6b0
d680  80eaf70c 80eaf768 80eaf774 80eaf9d8 80eafb08 80eafb14 80eafb2c 80eafb44
d6a0  80eafb5c 80eafb74 80eafb8c 80eafba4 80eafbbc 80eafbd4 80eafbec 80eafc04
d6c0  80eafc1c 80eafc34 80eafc4c 80eafc64 80eafc7c 80eafc94 80eafcac 80eafcc4
d6e0  80eafcdc 80eafcf4 80eafd74 80eafd8c 80eafda4 80eafdbc 80eafdd4 80eafdec
Process swapper/0 (pid: 1, stack limit = 0xbc06a238)
Stack: (0xbc06bef8 to 0xbc06c000)
bee0:                                                       80812a00 80f56000
bf00: bc06a000 80ec2250 80eaf6b0 00000000 80ecd680 0000016f 00000000 80eaf6f4
bf20: 00000000 800086ec 00000001 00000003 00000000 ffffffed 820c0dff 80049394
bf40: 80db4f38 80e388ec 00000006 00000006 80ee922c 80ec2270 00000006 80ec2250
bf60: 80f56000 80e7b428 80ecd680 0000016f 00000000 80e7bb8c 00000006 00000006
bf80: 80e7b428 80053d90 00000000 807d42b0 00000000 00000000 00000000 00000000
bfa0: 00000000 807d42b8 00000000 8000e158 00000000 00000000 00000000 00000000
bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 c719ef0f c62de1af
[<805d9468>] (caam_sm_startup+0x68/0x2a4) from [<80eaf6f4>] (caam_sm_init+0x44/0x5c)
[<80eaf6f4>] (caam_sm_init+0x44/0x5c) from [<800086ec>] (do_one_initcall+0xf4/0x154)
[<800086ec>] (do_one_initcall+0xf4/0x154) from [<80e7bb8c>] (kernel_init_freeable+0xfc/0x1c8)
[<80e7bb8c>] (kernel_init_freeable+0xfc/0x1c8) from [<807d42b8>] (kernel_init+0x8/0xe4)
[<807d42b8>] (kernel_init+0x8/0xe4) from [<8000e158>] (ret_from_fork+0x14/0x3c)
Code: e5840008 e1a01004 e1a00008 ebf76205 (e5858004)
usb 1-1: new high-speed USB device number 2 using ci_hdrc
---[ end trace d1fbb8c760753e8c ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
Rebooting in 5 seconds..
mxc_restart: Watchdog reset failed to assert reset
