T4240 usb boot
Question asked by varun k jayan on Oct 26, 2015
how to boot full rootfs image using the usb boot
at the uboot prompt iam getting the following error i have partitioned the usb and copied the full rootfs image on to the file
usb start - start (scan) USB controller
usb reset - reset (rescan) USB controller
usb stop [f] - stop USB [f]=force stop
usb tree - show USB device tree
usb info [dev] - show available USB devices
usb test [dev] [port] [mode] - set USB 2.0 test mode
    (specify port 0 to indicate the device's upstream port)
    Available modes: J, K, S[E0_NAK], P[acket], F[orce_Enable]
usb storage - show details of USB storage devices
usb dev [dev] - show or set current USB storage device
usb part [dev] - print partition table of one or all USB storage    devices
usb read addr blk# cnt - read `cnt' blocks starting at block `blk#'
    to memory address `addr'
usb write addr blk# cnt - write `cnt' blocks starting at block `blk#'
    from memory address `addr'
=> usb dev
USB device 0: Vendor: hp       Rev: 1100 Prod: v210w
            Type: Removable Hard Disk
            Capacity: 7680.0 MB = 7.5 GB (15728640 x 512)
=> usb dev device 0
=> usbboot device 0
Loading from usb device 0, partition 1: Name: usbda1  Type: U-Boot
** Unknown image type
