Problem with update via Freescale KDS Update Site - PEx Kinetis 3.0.0 plugin for Eclipse 4.4 (Luna)
Question asked by robert-lightwaverf on Oct 23, 2015
Latest reply on Oct 30, 2015 by robert-lightwaverf
I have a problem with update from Freescale KDS Update Site - http://freescale.com/lgfiles/updates/Eclipse/KDS (it was added to my eclipse after installing PEx Kinetis plugin.
Problem that occurs is:
An error occurred while collecting items to be installed
session context was:(profile=C__Users_Koper_cpp-luna_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Error closing the output stream for osgi.bundle,com.freescale.core.ide.license.nl1,1.5.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.core.ide.license.nl1_1.5.0.RT7_b1531-04803542804418466454793.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.doc.cde,1.1.0.RT7_b1530-1106 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.doc.cde_1.1.0.RT7_b1530-11064466256332312455341.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.doc.kds,1.0.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.doc.kds_1.0.0.RT7_b1531-0480282948402869928834.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.compatibility,1.0.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.compatibility_1.0.0.RT7_b1531-04804368230382907675719.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.databinding,1.4.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.databinding_1.4.0.RT7_b1531-04801682530837915840449.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.derivative.nl1,1.0.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.derivative.nl1_1.0.0.RT7_b1531-04807837937550619385096.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.kinetis,1.0.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.kinetis_1.0.0.RT7_b1531-04807334128493109128745.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.deviceinit,1.3.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.deviceinit_1.3.0.RT7_b1531-048076155549545242232.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.initsequence,1.2.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.initsequence_1.2.0.RT7_b1531-0480443593084880179703.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.inspector.custom.mcu,1.0.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.inspector.custom.mcu_1.0.0.RT7_b1531-04805480779264308306242.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.kds.newprojectwizard,1.2.1.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.kds.newprojectwizard_1.2.1.RT7_b1531-04805314235987320943406.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.kds.newprojectwizard.nl1,1.1.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.kds.newprojectwizard.nl1_1.1.0.RT7_b1531-04803190818547174406076.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.memorymap,1.4.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.memorymap_1.4.0.RT7_b1531-04801979031030090561806.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.pdd,1.6.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.pdd_1.6.0.RT7_b1531-04809002069258714737264.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.perspective,1.3.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.perspective_1.3.0.RT7_b1531-0480711146120752818525.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.projectview,1.3.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.projectview_1.3.0.RT7_b1531-04807137202796771459112.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.registers,1.4.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.registers_1.4.0.RT7_b1531-0480184983404310402383.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.ui.views,1.0.0.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.ui.views_1.0.0.RT7_b1531-0480766484271370463896.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.freescale.processorexpert.wizard.utils,1.3.1.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.freescale.processorexpert.wizard.utils_1.3.1.RT7_b1531-04804089302830806676824.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.processorexpert.core.ide.newprojectwizard.nl1,1.8.4.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.processorexpert.core.ide.newprojectwizard.nl1_1.8.4.RT7_b1531-04805303539990532227628.jar: Invalid zip file format
Error closing the output stream for osgi.bundle,com.processorexpert.core.ide.wizard.ui.nl1,1.4.5.RT7_b1531-0480 on repository file:/C:/Users/Koper/.p2/pool/.
Error unzipping C:\Users\Koper\AppData\Local\Temp\com.processorexpert.core.ide.wizard.ui.nl1_1.4.5.RT7_b1531-04807715825469034259329.jar: Invalid zip file format
Problems downloading artifact: org.eclipse.update.feature,com.freescale.doc.cde.feature,1.1.0.RT7_b1530-1106.
Downloaded stream not a valid archive. Check the server.
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processoreexpert.cde.feature,1.8.0.RT7_b1530-1106.
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processorexpert.feature.core,1.4.1.RT7_b1531-0480.
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processorexpert.feature.core.kpsdk,1.3.0.RT7_b1531-0480.
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processorexpert.feature.core.ui,1.4.0.RT7_b1531-0480.
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processorexpert.feature.core.wizards,1.4.0.RT7_b1531-0480.
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processorexpert.feature.custom.mcu,1.0.0.RT7_b1531-0480.
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processorexpert.feature.license,1.0.0.RT7_b1531-0480.
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processorexpert.feature.pinsettings,1.1.0.RT7_b1531-0480.
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processorexpert.kinetis.feature,3.0.1.b150806.
I also cannot install any new software using this i.e. I tried to install KSDK 1.2.0 Eclipse Update, i got similar error:
Problems downloading artifact: org.eclipse.update.feature,com.freescale.processorexpert.ksdk-1.2.0.sp,1.0.1.b150603.
