looking forward for the start up code for MPC 5777C using Diab, as the sample projects given in Diab does not have the same.
Got the startup code for the same using GHS, but the compiler dependency instrutions in startup routine/files - finding the same for Diab is seems to time consuming.
Hence looking for start upcode using Diab.
Thanks & Regards,
Srinivasan.A
