Freescale Kinetis K20 based MK20FN1M0VMD12 reset state question
sherry_zahid
I am working with MK20FN1M0VMD12 K20 based processor. I am looking at the default pin assignment in the datasheet, for example the pin "PTD11" says "disabled" under default. I understand that this means the pin will be disabled on reset. How does it behave exactly? Will PTD11 be pulled up/down? What exactly does "disabled" mean? Will I need to put an external (current limiting or pull up) resistor to this pin for microcontroller safety?
Thanks for your time,
Sherry
Paul_Tian
Hi, Sherry
Disable means high-impedance. So you have leave this pin floating.
Hope my reply can help you.
Best Regards
Paul
Paul_Tian
Hi, Sherry
Best Regards
Paul
sherry_zahid
Thanks Paul
