How to config IMX6DL DI0_PIN15 as LCD_ENABLE signel in device tree
Question asked by lin w on Oct 22, 2015
Latest reply on Nov 5, 2015 by lin w
my fb config GPIO:
     mxcfb1: fb@0 {
         compatible = "fsl,mxc_sdc_fb";
         disp_dev = "ldb";
         interface_pix_fmt = "RGB24";
         mode_str ="1280x800@60";
         default_bpp = <18>;
         int_clk = <0>;
         late_init = <0>;
         pinctrl-names = "default";
         my_lcd_pin = <&pinctrl_mylcd>;  /// or pinctrl-0 = <&pinctrl_ipu1_1>;
         status = "ok";
ping config :
     mylcdmux {
         pinctrl_mylcd: mylcd {
             fsl,pins = <
                 MX6QDL_PAD_DI0_PIN15__LCD_ENABLE 0x1b0b1
code in driver :
     plat_data->gpio_int = of_get_named_gpio(np, "my_lcd_pin", 0);   //  of_get_named_gpio(np, "default", 1);  ???
     if (plat_data->gpio_int == -EPROBE_DEFER)
         return -1;
     if (!gpio_is_valid(plat_data->gpio_int)) {
         printk("ERROR, emmmxxoo--->failed to get interrupt gpio\n");
         return 1;
     lcd_enable = gpio_get_value(plat_data->gpio_int);
     printk("shady---->lcd_eanble = %d\n", lcd_enable);
cmdline is:
console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,LDBXGA,if=RGB24,bpp=18 video=mxcfb1:off video=mxcfb2:off fbmem=10M fb0base
=0x27b00000 vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale androidboot.selinux=disabled androidboot.dm_v
erity=disabled
