how to use mutex on mqxlite?
yarannan
I am building a project that is based on platform KDS3.0 +KSDK1.2+PEx.
I am using MQXLite OS. It is not allow me to enable mutex. It said it doesnt
support. I have to run multi threads with some shared variables. Is there
any way that I can get around this issue?
Yaran
danielchen
Hi Yaran:
Here is a document to enable MQX Lite in KSDK1.1 , you can choose "mutexes"   component to enable mutex, and rebuild all.
How To: Create an MQX RTOS for KSDK project with Processor Expert in Kinetis Design Studio IDE
I tried it with KSDK1.3 , it seems mutex is hidden in this version, it only suuport lightweight events and lightweight message queues in this version
danielchen
Hi Yaran:
MQX Lite supports lightweight subset of the MQX componets: LW semaphore, LW evet, Mutex, LW message.
There is an example using mutex
C:\Freescale\CW MCU v10.6\MCU\CodeWarrior_Examples\Processor_Expert\MQXLite\Kinetis\FRDM_KL25Z\MUTEX_KL25Z
Mutex is an optional component, the default state is disable.
I think if you add the below line into user_config.h, and recompile all. it should able to support mutex.
#define MQX_USE_MUTEXES           1
I am attaching the mqxlite user manual here.
yarannan
I did that and it threw me error when I run the program. It said
DescriptionResourcePathLocationType
#error MUTEX component is currently disabled in MQX kernel. Please set MQX_USE_MUTEXES to 1 in mqx_sdk_config.h and recompile kernel.mutex.h/shiny_v3/SDK/rtos/mqx/mqx/source/includeline 36C/C++ Problem
So how would i be able to recompile the kernel from KDS?
danielchen
Hi Yaran:
