dear freescale team.
i could see about OTPMK in some manuals .
The OTPMK is same with OTP_SRK[0~7] ?
it's really confusing.
it does not mention about OTPMK in IMX6DQRM.pdf file.
i can find only OTP_SRK.
there are SFP_SRKHR n(Super Root Key Hash n) , One Time Programmable Master Key n (SFP_OTPMKRn) each in case of other freescale board in the fuse...
thank you.
HI MyungJin
one can determine if a valid OTPMK has been burned by checking the
OTPMK_ZERO bit in the SNVS_HP Status Register.
In early pre-production parts they did not have the OTPMK fuses provisioned.
On production parts, the OTPMK are be burned by Freescale prior to shipping the
device. The value burned by Freescale is random and not recorded. The intent
of the OTPMK is to be a secret key that is only known to CAAM.
Thanks for your reply.
To fuse OTPMK where i should write the values.
is it the OTP_SRK[0~7] ?
HI MyungJin
no this is not OTP_SRK, please create service request.
Thank you...
you mean OTP_SRKn is different with OTPMK right?
and i don't understand "create service request".
what is it? could you explain it more detailed?
MyungJin Hwang
please login to freescale.com then enter service request
I will send you address OTPMK.
~igor
It's the Service Request number 1-4138548724
and could i read the OTPMK and ZMK values directly? or it's to be a secret key that is only known to CAAM ?
thank you for your support.
