KL17Z Flash Security Protection FPROT and FSEC using fsl_flash KDS component
Question asked by sys@allmatic.com on Oct 22, 2015
Latest reply on Oct 27, 2015 by sys@allmatic.com
Hi all,
I'm using MKL17Z256VFM4 on KDS for our project: for data storage I'm using the high-level component "fsl_flash" provided with Kinetis SDK driver.
I have this question: how should I do to protect the whole code-flash area? I mean, how to set FPROT register from Flash Configuration Field, that then affects FTFA_FSEC register?
On datasheet I read that it has to be set in the boot/reset sequence, so I think not in main.c module, am I right?
But, I dont see any way to pre-set the FPROT register directly from Processor Expert.
I see this setting in the low-level "Init_FTFL", but I cannot set it in the high-level one, and I dont want to have to use low-level component.
How can I do?
Thanks in advance!
Sandro
