I want to switch to IPU1_DISP1 pins in the SDK example of the RGB panel. I am enabling the pins with the correct ALT value according to manual, and changing di=0 to di=1, in ipu_display_setup() in ipu_common.c. However I am not seeing any signals coming out of the DISP1 pins.
Is there something else that needs to be changed?
Thanks.
