i.mx6 HAB secure boot freeze at hab_rvt_entry
Question asked by ZC Tee on Oct 22, 2015
Latest reply on Nov 10, 2015 by ZC Tee
Hi all,
I am trying to implement the HAB functionality into the uboot for my i.mx6 system.
I failed to do so as my uboot always get freeze at hab_rvt_entry
I had done some searching, and found out post below:
i.MX6 Secure Boot HAB API within U-Boot calls freezing
However, my system still freeze at the same location after i enable the CAAM clock by doing the following:
void hab_caam_clock_enable(void)
       u32 reg = 0;
       reg = readl(CCM_BASE_ADDR + CLKCTL_CCGR0); /* CCGR0 */
       reg |= 0x3F00; /*CG4 ~ CG6, enable CAAM clocks*/
       writel(reg, CCM_BASE_ADDR + CLKCTL_CCGR0);
       reg = readl(CCM_BASE_ADDR + CLKCTL_CCGR6); /* CCGR6 */
       reg |= 0x0C00; /*CG5, enable CAAM clocks*/
       writel(reg, CCM_BASE_ADDR + CLKCTL_CCGR6);
Can anyone advice me on what is going wrong? Is there something that i missed?
I am using u-boot 2009.08.
*in the uboot console, i always get
HAB Configuration: 0x00, HAB State: 0x00
Does it means anything?
Thank you.
ZC
