Hello all,
i am new to Freescale Community. I would like to understand how can i program the daughter board in the 3PHASELV-KIT. I don't understand if it is everything inside the board or i need an external programmer.
Thanks in advance,
Michele
Solved! Go to Solution.
Hi Michele
You need and external programmer to program the daughter board. If you are using the S08MP you need a BDM like the universal multilink, if you are using the MC56F then you need a Jtag. please check the following document for more detail
and
regards
Vicente Gomez
