Makefile for iMX6 SDK
tejummb
Hi Everyone,
I'm using imx6_platform_sdk_v1.1.0 for my application.
The documentation mentions that the Gnu make version 3.81 or later is required.
I'm using version 4.0. Even then, I'm getting makefile errors.
Kindly, let me know if I'm using the right version of SDK.
Labels (4)
gary_bisson
Senior Contributor III
Please copy/paste your output. As a FYI, I am using GNU Make version 4.0 as well and it works just fine.
Make sure to follow the README.pdf, especially the toolchain setup and the build command (./tools/build_sdk).
Gary
tejummb
Hi Gary,
I apologize for my delayed response.
I'm using the 30-day trial edition of sourcery codebench. And, I'm getting the following error:
tejummb@tejummb-VirtualBox:~/SDK/iMX6_Platform_SDK$ ./tools/build_sdk -target=mx6dq -board=evb -test=caam
Building sdk [mx6dq evb a]
Compiling sdk/utility/src/runtime_support.c
/home/tejummb/SDK/iMX6_Platform_SDK/sdk/utility/src/runtime_support.c:38:19: fatal error: reent.h: No such file or directory
#include <reent.h>
compilation terminated.
make[2]: *** [/home/tejummb/SDK/iMX6_Platform_SDK/output/mx6dq/lib/obj/sdk/sdk/utility/src/runtime_support.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [utility] Error 2
make: *** [sdk] Error 2
Build mx6dq evb rev_a caam failed with return code 2!
I have followed the instructions exactly as given in the README file. Kindly, let me know the ways resolve the issue.
Teju M M B
