NFS boot for Sabre AI
Question asked by PRAMIR SARKAR on Oct 19, 2015
Latest reply on Oct 26, 2015 by jimmychan
I have followed the NFS / tftp boot for Android Lollipop on sabre AI imx6Q.
i am struck up with the following."Starting kernel ..."  and doesnt proceed after that ..
Kindly help:
I have pasted both the logs and Environment variables i am using
U-Boot 2014.04-00201-g9d7bf9b (May 05 2015 - 09:57:57)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
CPU:   Temperature 38 C, calibration data: 0x5844cf7d
Reset cause: POR
Board: MX6-Sabreauto revA
I2C:   ready
DRAM:  2 GiB
NAND:  0 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=11
check_and_clean: reg 0, flag_set 0
Fastboot: Normal
flash target is MMC:1
Net:   FEC [PRIME]
Normal Boot
Hit any key to stop autoboot:  0
=> tftpboot 0x14f00000 imx6q-sabreauto.dtb ;tftpboot 0x15000000 uramdisk.img; tftpboot 0x14008000 uImage ;
Using FEC device
TFTP from server 10.204.222.21; our IP address is 10.204.222.6
Filename 'imx6q-sabreauto.dtb'.
Load address: 0x14f00000
Loading: ##########
         835.9 KiB/s
done
Bytes transferred = 50535 (c567 hex)
Using FEC device
Filename 'uramdisk.img'.
Load address: 0x15000000
Loading: #################################################################
         853.5 KiB/s
done
Bytes transferred = 725613 (b126d hex)
Using FEC device
Filename 'uImage'.
Load address: 0x14008000
         828.1 KiB/s
done
Bytes transferred = 6819464 (680e88 hex)
=> bootm 0x14008000 0x15000000 0x14f00000
## Booting kernel from Legacy Image at 14008000 ...
   Image Name:   Linux-3.10.53
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    6819400 Bytes = 6.5 MiB
   Load Address: 14008000
   Entry Point:  14008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 15000000 ...
   Image Name:   Android Root Filesystem
   Image Type:   ARM Linux RAMDisk Image (uncompressed)
   Data Size:    725549 Bytes = 708.5 KiB
   Load Address: 15000000
   Entry Point:  15000000
## Flattened Device Tree blob at 14f00000
   Booting using the fdt blob at 0x14f00000
   XIP Kernel Image ... OK
   Using Device Tree in place at 14f00000, end 14f0f566
Starting kernel ...
Get struck here.........................
My Environment variables are
=> pri
baudrate=115200
bootargs=console=ttymxc3,115200 init=/init video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 video=mxcfb2:off video=mxcfb3:off vmalM
bootcmd=run tftp_nfs_boot
bootdelay=1
bootfile=uImage
console=ttymxc3,115200n8
dtbaddr=0x14f00000
ethact=FEC
ethaddr=00:04:9f:03:b3:fb
ethprime=FEC
fastboot_dev=mmc1
fdt_addr=0x14f00000
fdt_file=imx6q-sabreauto.dtb
fdt_high=0xffffffff
fdtaddr=0x14f00000
fdtfile=imx6q-sabreauto.dtb
fileaddr=14f00000
filesize=c567
gatewayip=10.204.222.1
image=zImage
initrd_high=0xffffffff
ip_dyn=no
ipaddr=10.204.222.6
ldo_active=off
loadaddr=0x14008000
netargs=setenv bootargs console=ttymxc3,115200 root=/dev/nfs ip=10.204.222.6 nfsroot=10.204.222.21:/home/ranjini/SABRE_AUTO/NFS_SYSTEp
netmask=255.255.255.192
nfsroot=/home/ranjini/SABRE_AUTO/NFS_SYSTEM/SABRE_AI_NFS_IMAGES
ramdiskaddr=0x15000000
ramdiskfile=uramdisk.img
serverip=10.204.222.21
splashpos=m,m
tftp_nfs_args=setenv bootargs mem=128M console=${console} noinitrd rw ip=10.204.222.6 nfsroot=${serverip}:${tftp_nfs_fs}
tftp_nfs_boot=run tftp_nfs_img;run tftp_nfs_args; bootm ${loadaddr}
tftp_nfs_fs=/home/ranjini/SABRE_AUTO/NFS_SYSTEM/SABRE_AI_NFS_IMAGES,nolock,rsize=1024,wsize=1024
tftp_nfs_img=tftp ${loadaddr} ${bootfile}
Environment size: 1436/8188 bytes
