autorun-vpu.sh
Question asked by grim on Oct 19, 2015
Latest reply on Jun 9, 2016 by vikash patil
I'm trying to test the VPU in my system and every time I run 'autorun-vpu.sh' I get the following output.
root@imx6solosabresd:/unit_tests# ./autorun-vpu.sh
Checking for devnode: /dev/mxc_vpu
autorun-vpu.sh: PASS devnode found: /dev/mxc_vpu
Running test case: ./mxc_vpu_test.out -C config_dec
/unit_tests/test-utils.sh: line 11: ./mxc_vpu_test.out: No such file or directory
autorun-vpu.sh: FAIL test case: ./mxc_vpu_test.out -C config_dec
autorun-vpu.sh: Exiting FAIL
It doesn't seem to matter if I run this on a SabreSD board, our custom imx6 solo or imx6 quad board.
I built the binaries with Fido distribution of Yocto (fsl-image-machine-test).
All of the other tests I've ran seem to work.... except for this one.
Anybody else have this issue? How did you get around it?
