ltib issues
Question asked by sarathkumar natarajan on Oct 18, 2015
Latest reply on Oct 21, 2015 by gusarambula
hi there,
             i'm getting the following error while running ./ltib anyone help me
ltib cannot be run because one or more of the host packages needed to run it
are either missing or out of date or not in ltib's standard path.  Please
install/upgrade these packages on your host.  If you have your own utilities
in non-standard paths, please add an entry into the .ltibrc file for example:
%path_std
/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/my/own/exes
Package                Minimum ver   Installed info
zlib                   0             not installed
Died at ./ltib line 1409.
traceback:
main::host_checks:1409
  main:554
Started: Sun Oct 18 11:13:59 2015
Ended:   Sun Oct 18 11:14:02 2015
Elapsed: 3 seconds
Build Failed
Exiting on error or interrupt
