t4240rdb boot error
t4240rdb boot error
varunkjayan
i have loaded a new image fsl-image -core changing conf to add gcc,make etc
and the file size is big
when i load the file the file shows that the file
error fs ext2 :u image cannot be defined 10755 fsl-image minimal
and also showing
error at stack 0x701 iam not able to boot my system
please help
Pavel
Do you use the ext2.gz.u- boot file of the fsl-mage-core file system?
Pavel
varunkjayan
yes
Pavel
Try to use fsl-image-full for your changing.
Pavel
