T1040 toolchain vtss issue
Question asked by Kees Trommel on Oct 14, 2015
Latest reply on Oct 23, 2015 by Yiping Wang
I have built a custom fsl-toolchain that includes l2switch, this by adding the following recipe to the new layer meta-fsl-custom
/meta-fsl-custom/images/fsl-toolchain-custom.bb:
require recipes-core/meta/meta-toolchain.bb
MULTILIBS_pn-${PN} = ""
TOOLCHAIN_NEED_CONFIGSITE_CACHE += "zlib"
TOOLCHAIN_TARGET_TASK += " \
    l2switch \
    i2c-tools \
    glib-2.0 \
    glib-2.0-dev \
    libcrypto \
    dtc-staticdev \
    libgomp \
    libgomp-dev \
    libgomp-staticdev \
    libstdc++-staticdev \
    ${TCLIBC}-staticdev \
CORE_SPECIFIC = " \
    nativesdk-mux-server \
    nativesdk-pme-regex-analyzer \
CORE_SPECIFIC_ls102xa = ""
TOOLCHAIN_HOST_TASK += " \
    nativesdk-dtc \
    nativesdk-u-boot-mkimage \
    nativesdk-cst \
    nativesdk-e2fsprogs \
    ${CORE_SPECIFIC} \
TOOLCHAIN_HOST_TASK_append_e500v2 = " \
    nativesdk-boot-format \
    nativesdk-boot-format-config \
The toolchain generated by this recipe contains as expected the vtss header files and vtss libraries. However when I include the header vtss_api.h as recommended as follows
#include <vtss_api/vtss_api.h>
I get the following compile error
In file included from /local/ctrommel/hermes/file.c:4:0,
/home/ctrommel/QorIQ-SDK-V1.7/sysroots/ppce5500-fsl-linux/usr/include/vtss_api/vtss_api.h:35:21: fatal error: vtss_os.h: No such file or directory
#include <vtss_os.h>
Does a patch exist that fixes this issue?
