How to enable and access i2c bus 3 in kernel?
naveennvn
Hi all,
     I'm using LS2085A board. By default i2c bus 0 is selected , there we can able to read and write the register values.
     I need to read the register values from i2c bus 3.
     In u-boot i can able to read those registers. For selecting i2c bus 3 i used "i2c dev 3" command.
     But in kernel i can't able to select and read the i2c bus 3.I tried via accessing /dev/i2c-3 but i'm not getting.  I don't know how to select the bus 3.
     Can any one help me on this?
     Thanks in advance,
-Naveen
Tags (2)
yipingwang
Hello naveennvn,
You could use i2c-tools package to do verification, please add "i2c-tools" in IMAGE_INSTALL variable of recipe meta-fsl-networking/image/fsl-image-core.bb and rebuild image with "bitbake fsl-image-kernelitb".
root@ls2085aqds:~# i2cdetect 3
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-3.
I will probe address range 0x03-0x77.
Continue? [Y/n] Y
    0  1  2  3  4  5  6 7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: 60 -- -- -- -- -- 66 67 -- -- -- -- 6c 6d -- --
70: -- -- -- -- -- -- -- UU
root@ls2085aqds:~# i2cget -y 3 0x66 0x2 b
0x07
root@ls2085aqds:~# i2cdump 3 0x66
No size specified (using byte-data access)
I will probe file /dev/i2c-3, address 0x66, mode byte
Continue? [Y/n] Y
    0  1  2  3  4  5  6 7  8  9  a  b  c  d  e f    0123456789abcdef
00: 33 12 07 01 b7 04 00 00 00 00 00 3b df 00 00 00 3?????.....;?...
10: 20 00 00 11 00 00 00 8c 00 00 00 00 00 50 a0 7f ..?...?.....P??
20: 00 00 62 00 cb ff 7f ff 00 00 00 00 00 00 00 00 ..b.?.?.........
30: 32 00 00 12 04 0b 18 ff 18 ff 00 00 00 00 00 00 2..????.?.......
40: 30 00 06 00 00 00 00 00 61 00 00 00 00 00 00 00 0.?.....a.......
50: 80 32 af 03 02 30 a1 08 06 c5 c0 28 7b 20 35 08 ?2???0?????({ 5?
60: 12 ff ff ff ff ff ff ff 00 00 00 ff ff ff ff ff ?...............
70: 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 .........?......
80: ee c0 ff ff 00 00 00 00 ff ff ff c0 00 00 00 00 ??.........?....
90: ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
a0: 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 .........?......
b0: 00 09 09 00 00 00 00 00 00 00 00 00 00 00 00 00 .??.............
c0: 2f af 3f 95 00 01 00 00 00 00 00 00 03 00 20 00 /???.?......?. .
d0: 00 00 00 00 38 40 00 00 00 0c 00 00 05 c0 00 80 ....8@...?..??.?
e0: 00 00 00 00 cb 17 da 1d 00 00 00 00 00 00 00 11 ....????.......?
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Yiping
naveennvn
Hi Yiping,
     Thanks for your response,
     Actually in my setup i had connected the some peripherals in i2c bus 3.
     In u-boot it shows properly :
          => i2c dev 3
          Setting bus to 3
          => i2c probe
          Valid chip addresses: 00 4C 50
     But in kernel those slave addresses are not showing :
          root@ls2085aissd:~# i2cdetect -y 3
          60: 60 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
     Why those slave addresses are not showing on kernel ? How to enable in kernel ?
     Can you help me on this ?
-Naveen
yipingwang
Hello naveennvn,
Please check whether Kernel configuration contains the following.
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
CONFIG_I2C_IMX=y
For the dts file, please enable fsl-ls2085a.dtsi and with i2cx node enabled.
If your problem remains, would you please also attach Kernel boot log.
Yiping
naveennvn
Hi Yiping,
     Above kernel configurations all are already enabled and i2c node also enabled in fsl-ls2085a.dtsi file.
     Now also the problem remains same. I'm not able to access the i2c bus 3 in kernel.
     Is there any modifications in board files?
Here is the i2c related kernel log :
[    2.388000] SCSI subsystem initialized
[    2.391937] usbcore: registered new interface driver usbfs
[    2.397486] usbcore: registered new interface driver hub
[    2.402894] usbcore: registered new device driver usb
[    2.408250] i2c i2c-0: IMX I2C adapter registered
[    2.413012] i2c i2c-0: can't use DMA
[    2.416646] genirq: Flags mismatch irq 14. 00000000 (2010000.i2c) vs. 00000000 (2000000.i2c)
[    2.425170] imx-i2c 2010000.i2c: can't claim irq 14
[    2.430092] imx-i2c: probe of 2010000.i2c failed with error -16
[    2.436149] i2c i2c-1: IMX I2C adapter registered
[    2.440888] i2c i2c-1: can't use DMA
[    2.444509] genirq: Flags mismatch irq 15. 00000000 (2030000.i2c) vs. 00000000 (2020000.i2c)
[    2.453032] imx-i2c 2030000.i2c: can't claim irq 15
[    2.457950] imx-i2c: probe of 2030000.i2c failed with error -16
[    2.463968] pps_core: LinuxPPS API ver. 1 registered
[    2.468974] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    4.449215] i2c /dev entries driver
[    4.453471] i2c i2c-0: Added multiplexed i2c bus 2
[    4.458348] i2c i2c-0: Added multiplexed i2c bus 3
[    4.463238] i2c i2c-0: Added multiplexed i2c bus 4
[    4.468247] i2c i2c-0: Added multiplexed i2c bus 5
[    4.473127] i2c i2c-0: Added multiplexed i2c bus 6
[    4.477998] i2c i2c-0: Added multiplexed i2c bus 7
[    4.482908] i2c i2c-0: Added multiplexed i2c bus 8
[    4.487783] i2c i2c-0: Added multiplexed i2c bus 9
[    4.492579] pca954x 0-0077: registered 8 multiplexed busses for I2C mux pca9547
-Naveen
