MX6 SoloX bare metal startup and Manufacturing tool
Question asked by Yashavanthkumar Naik on Oct 13, 2015
I have used A9_launch_m4 example and able to run the code if I flash this code to SD card on imx6 solox SABRE development board.
But when I tried to flash this code to QSPI NOR flash memory using manufacturing tool, I am able to flash it without any error but I did not see any output on UART.
Please refer the attached files (Example and Manufacturing tool files)
Can you please tell me if I need to change the sources(.c or .h files) or the manufacturing tool files (ini or ucl2 files) to make this example to work with QSPI memory?
Original Attachment has been moved to: ucl2.xml.zip
Original Attachment has been moved to: MX6SX_example-A9_launch_m4.zip
Original Attachment has been moved to: cfg.ini.zip
