Using JTAG with the i.MX 6UltraLite EVK
richardyearsley
I've been given an i.MX 6UltraLite EVK board by a colleague to be modified for use with JTAG. The 'i.MX 6UltraLite EVK Board Hardware User’s Guide' (page 14) states: Remove R1407, R1431~R1434 resistors while using JTAG debug. However, the PCB does not have silk-screen designators for these components, so I don't know which ones to remove. I've searched your website for SCH-28616 to at least find the schematic, but this produces no results other than the user guide. There are board layout files for the duaghter-board which show all the designators on that board, but nothing for the mother-board (700-28616 REVB).
Please could you give me a link to download the files for the mother-board so that I can make these modifications?
Many thanks,
Richard Yearsley
Senior Hardware Design Engineer
ARM Ltd.
Hi Richard
SCH-28616 and layout files can be found on MCIMX6UL-EVK:
i.MX6ULtraLite Evaluation Kit product page
Schematics (1)
Design files, including hardware schematics, Gerbers, and OrCAD files. (REV 0)
ZIP (9.9 MB) MCIMX6UL-EVK_DESIGNFILES
i.MX6ULtraLite Evaluation Kit|Freescale
Hi Richard
Schematics (1)
richardyearsley
Thank you Igor.
I'd already looked at those files, but I must have missed the right folder.
Richard
atmaprakashpand
Hi Richard,
I am also working on the i.MX 6 ULtraLite EVK (MCIMX6UL-EVK). I am using processor expert tool for building my code. I have successfully compiled the hello world code using arm cross tool chain. Now, I want to run my code on baremetal(with out using linux). I came to know that we need to use jtag debugger from jlink for running the code on baremetal. I have few questions regarding this.
1) Could you please let me know what is the jlink model (is it jlink EDU?) you are using for debugging?
2) If I don't want to use jlink debugger, Can I use either Debug USB port(J1901) or USB OTG port(J1102) to run the .elf file.
Atma
