in the Tutorial: Kinetis L Series Tutorial - Touch-Sensing with Processor Expert I get an error in the events.c TSS1_fCallBack0 stating: undefined reference to `TU1_SetOffSetTicks' any ideas on a fix. I tried using #include TU1.h.
Solved! Go to Solution.
This demo project is developed on earlier CodeWarrior version which includes the FSL compiler. So it will have some problem when build it with gcc in CodeWarrior v10.6.4.
I would like to suggest you to use an example from the TSS library on path: C:\Freescale\Freescale_TSS_3_1\examples\FRDMKLXX_DEMO
This demo software can be downloaded from:
Here you will find information about how to configure your project in order to include and implement the TSS library.
http://mcuoneclipse.com/2012/09/30/tutorial-touching-the-freedom-kl25z-board/
Fiona Kuang
Technical Information & Commercial Support
Fiona Kuang
seems like you are missing TimerUnit_LDD component (driver) in project. You can add it from "Components Library" view.
best regards
Vojtech Filip
