How do you re-enable double-click to go to error location?
dave408
Senior Contributor II
KDS used to take me to the exact location of a warning or error when I would double-click on them, but it no longer does this.  I did some searching online for Eclipse and CDT-related errors like this.  The warnings and errors appear highlighted in the Console window, but the strange thing is that they are not added to the Problems window.
The settings look reasonable to me:
Can anyone suggest something else that I need to check?
Tags (2)
dave408
The strange thing is that I'm also debugging a problem where my application fails to start, and when I commented out some code I was debugging, the double-click feature started working again.
Carlos_Mendoza
Hi Dave,
It's good to hear the double-click feature started working again, please let us know if you encounter this problem again.
Best Regards!
Carlos Mendoza
Technical Support Engineer
