MPC5777C - Fast Ethernet Controller (FEC)
Himenez
I need to use internal FEC with an external MAC device (SMSC LAN8740A).
My PHYs that do not have all the MII pins, for this reason I've chose  MII-Lite configuration.
I've configured all registers as I think are good but unfortunately my FEC don't dialogue correctly with external MAC.
In attachment my hardware configuration, this is my software configuration:
static int drvOpen( NGifnet *netp)
  FEC_regs *regs;
  NGfecif_bd *RxTxBD;
  int i, ictl;
  * check stack configuration (must be divisible by 16)
  if( ((ngBufDataOffset + ngBufDataMax) & 15) != 0)    return( NG_ENXIO);
  ng_siu_init();
  * install PHY/MII functions
  NG_ETHIF_DATA( netp, eif_phy_write) = phy_write;
  NG_ETHIF_DATA( netp, eif_phy_read)  = phy_read;
   * Initialize ptr for config access
  regs = (FEC_regs *) (ngM68K_MBAR + FEC_OFFSET);
  * Ethernet Control Register   * - reset device
  regs->FEC_ECR = ECR_RESET;
  * Initialize Tx and Rx Descriptors
  netp->if_devptr1 = (void *) (( ((NGuint) netp) + sizeof(NGfecifnet) + 15) & ~15);
  RxTxBD = (NGfecif_bd *)netp->if_devptr1;
  * RxBDs
  for( i=0; i<NG_FECIF_NUM_RXBDS; i++) {
    /* allocate buffer for reception */
    ngBufAlloc( ((NGfecifnet *) netp)->Bufi[i] );
    ((NGfecifnet *) netp)->Bufi[i]->buf_datap =
      (NGubyte *)((NGfecifnet *) netp)->Bufi[i] + netp->if_dev1;
    ((NGfecifnet *) netp)->Bufi[i]->buf_datalen = 0;
    /* prepare RxBD */
     RxTxBD->RxBD[i].bd_addr    = ((NGfecifnet *) netp)->Bufi[i]->buf_datap;
     RxTxBD->RxBD[i].bd_length  = 0;
     RxTxBD->RxBD[i].bd_cstatus = BD_RX_E;
  RxTxBD->RxBD[NG_FECIF_NUM_RXBDS-1].bd_cstatus |= BD_RX_W;
  ((NGfecifnet *) netp)->RxIdx = 0;
  * TxBDs
  for( i=0; i<NG_FECIF_NUM_TXBDS; i++) {
    /* prepare TxBD */
    RxTxBD->TxBD[i].bd_cstatus = 0;
    ((NGfecifnet *) netp)->Bufo[i] = NULL;
  RxTxBD->TxBD[NG_FECIF_NUM_TXBDS-1].bd_cstatus |= BD_TX_W;
  ((NGfecifnet *) netp)->TxCount   = 0;
  ((NGfecifnet *) netp)->TxIdxAdd  = 0;
  ((NGfecifnet *) netp)->TxIdxDel  = 0;
  * Interrupt Mask Register
  regs->FEC_EIMR = EIMR_TXF|EIMR_RXF;
  * clear interrupts
  regs->FEC_EIR  = ~0;
  * set mac address
  regs->FEC_PALR = (NGuint)(NG_ETHIF_DATA( netp, eif_addr[0])<<24) |
    (NG_ETHIF_DATA( netp, eif_addr[1])<<16) |(NG_ETHIF_DATA( netp, eif_addr[2])<<8)  |
    (NG_ETHIF_DATA( netp, eif_addr[3]));
  regs->FEC_PAUR = (NGuint)(NG_ETHIF_DATA( netp, eif_addr[4])<<24) | (NG_ETHIF_DATA( netp, eif_addr[5])<<16);
  * set multicast filter
  drvSetMulti( netp);
  * Set EMRBR  - Max. Receive Buffer Length
  regs->FEC_EMRBR = netp->if_dev2;
  * Receive Descriptor Ring Start Register
  regs->FEC_ERDSR = (NGuint) &RxTxBD->RxBD[0];
  * Transmit Buffer Descriptor Ring - Start Register
  regs->FEC_ETDSR = (NGuint) &RxTxBD->TxBD[0];
  * Receive Control Register - disable internal LoopBack
  regs->FEC_RCR &= ~RCR_LOOP;
  * MII Speed Control Register
  regs->FEC_MSCR = (0x00000005<<1);
  * MII mode (or lite), not 7 wire
  regs->FEC_RCR |= RCR_MII_MODE;
  * Promiscuous mode - All frames are accepted regardless of address matching.
  regs->FEC_RCR |= RCR_PROM;
  regs->FEC_RCR &= 0x0000FFFF;
  regs->FEC_RCR |= ((netp->if_dev2)<<16);
  * Full duplex operation
  regs->FEC_TCR = TCR_FDEN;
  * Transmit FIFO Watermark -  (0x02 = 192 bytes written)
  regs->FEC_TFWR = 0x03;
  * install interrupt handlers
  ngOSIsrAttach ( 194, (void (*)(void *)) drvHandler, netp );
  ngOSIsrAttach ( 195, (void (*)(void *)) drvHandler, netp );
  ngOSIsrAttach ( 196, (void (*)(void *)) drvHandler, netp );
  * MIB Control Register
  regs->FEC_MIBC = 0x00000000;
  * - enabled, device
  regs->FEC_ECR |= ECR_ETHER_EN;
  * Receive Descriptor Active Register
  regs->FEC_RDAR = RDAR_R_DES_ACTIVE;
  return( NG_EOK);
