How to initialize IMX6 using JLink
davidziv
Hello.
I'm using IMX6 SOLO, I'm trying to write to Spansion (S25FL512SAGBHIC10) SPI NOR Using JLink.
1. Which registers needed to be initialized on IMX6 before starting the process (EIM config, clocks etc...)
2. Which memory address should I use to copy the content to? (0x8080000)
I don't have access to USB OTG, so the mfg tool is not relevant.
I'll appreciate any assistance.
David.
davidziv
OK, found the right configuration for running U-BOOT from RAM
target remote localhost:2331
#monitor endian little
#monitor device MCIMX6S5
#monitor speed auto
monitor reset
monitor halt
monitor sleep 1000
# Disable WDOG
monitor memU32 0x020bc000 = 0x30
# Enable all clocks (they are disabled by ROM code)
monitor memU32 0x020c4068 = 0x00C03F3F
monitor memU32 0x020c406c = 0x0030FC03
monitor memU32 0x020c4070 = 0x0FFFC000
monitor memU32 0x020c4074 = 0x3FF00000
monitor memU32 0x020c4078 = 0x00FFF300
monitor memU32 0x020c407c = 0x0F0000C3
monitor memU32 0x020c4080 = 0x000003FF
#GPU and VPU not needed for boot
#monitor memU32 0x020c4084 = 0xffffffff
# IOMUX
#DDR IO TYPE:
monitor memU32 0x020e0774 = 0x000C0000 # IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE
monitor memU32 0x020e0754 = 0x00000000 # IOMUXC_SW_PAD_CTL_GRP_DDRPKE
#CLOCK:
monitor memU32 0x020e04ac = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_0
monitor memU32 0x020e04b0 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_1
#ADDRESS:
monitor memU32 0x020e0464 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_CAS
monitor memU32 0x020e0490 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_RAS
monitor memU32 0x020e074c = 0x00000030 # IOMUXC_SW_PAD_CTL_GRP_ADDDS
#Control:
monitor memU32 0x020e0494 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_RESET
monitor memU32 0x020e04a0 = 0x00000000 # IOMUXC_SW_PAD_CTL_PAD_DRAM_SDBA2 - DSE can be configured using Group Control Register: IOMUXC_SW_PAD_CTL_GRP_CTLDS
monitor memU32 0x020e04b4 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT0
monitor memU32 0x020e04b8 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT1
monitor memU32 0x020e076c = 0x00000030 # IOMUXC_SW_PAD_CTL_GRP_CTLDS
#Data Strobes:
monitor memU32 0x020e0750 = 0x00020000 # IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL
monitor memU32 0x020e04bc = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0
monitor memU32 0x020e04c0 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1
monitor memU32 0x020e04c4 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS2
monitor memU32 0x020e04c8 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS3
#Data:
monitor memU32 0x020e0760 = 0x00020000 # IOMUXC_SW_PAD_CTL_GRP_DDRMODE
monitor memU32 0x020e0764 = 0x00000030 # IOMUXC_SW_PAD_CTL_GRP_B0DS
monitor memU32 0x020e0770 = 0x00000030 # IOMUXC_SW_PAD_CTL_GRP_B1DS
monitor memU32 0x020e0778 = 0x00000030 # IOMUXC_SW_PAD_CTL_GRP_B2DS
monitor memU32 0x020e077c = 0x00000030 # IOMUXC_SW_PAD_CTL_GRP_B3DS
monitor memU32 0x020e0470 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM0
monitor memU32 0x020e0474 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM1
monitor memU32 0x020e0478 = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM2
monitor memU32 0x020e047c = 0x00000030 # IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM3
# DDR Controller Registers
# Manufacturer: ISSI
# Device Part Number: IS43/46TR16256AL
# Clock Freq.: 400MHz
# Density per CS in Gb: 8
# Chip Selects used: 1
# Number of Banks: 8
# Row address:     15
# Column address: 10
# Data bus width 32
# Calibration setup.
monitor memU32 0x021b0800 = 0xA1390003 # DDR_PHY_P0_MPZQHWCTRL, enable both one-time & periodic HW ZQ calibration.
# For target board, may need to run write leveling calibration to fine tune these settings.
monitor memU32 0x021b080c  = 0x001F001F
monitor memU32 0x021b0810 = 0x001F001F
##Read DQS Gating calibration
monitor memU32 0x021b083c = 0x42190219 # MPDGCTRL0 PHY0
monitor memU32 0x021b0840 = 0x017B0177 # MPDGCTRL1 PHY0
#Read calibration
monitor memU32 0x021b0848 = 0x4B4D4E4D # MPRDDLCTL PHY0
#Write calibration
monitor memU32 0x021b0850 = 0x3F3E2D36 # MPWRDLCTL PHY0
#read data bit delay: (3 is the reccommended default value, although out of reset value is 0)
monitor memU32 0x021b081c = 0x33333333 # DDR_PHY_P0_MPREDQBY0DL3
monitor memU32 0x021b0820 = 0x33333333 # DDR_PHY_P0_MPREDQBY1DL3
monitor memU32 0x021b0824 = 0x33333333 # DDR_PHY_P0_MPREDQBY2DL3
monitor memU32 0x021b0828 = 0x33333333 # DDR_PHY_P0_MPREDQBY3DL3
# Complete calibration by forced measurement:
monitor memU32 0x021b08b8 = 0x00000800 # DDR_PHY_P0_MPMUR0, frc_msr
# Calibration setup end
#MMDC init:
monitor memU32 0x021b0004 = 0x0002002D # MMDC0_MDPDC
monitor memU32 0x021b0008 = 0x00333030 # MMDC0_MDOTC
monitor memU32 0x021b000c = 0x3F435313 # MMDC0_MDCFG0
monitor memU32 0x021b0010 = 0xB66D8B63 # MMDC0_MDCFG1
monitor memU32 0x021b0014 = 0x01FF00DB # MMDC0_MDCFG2
#MDMISC: RALAT kept to the high level of 5.
#MDMISC: consider reducing RALAT if your 528MHz board design allow that. Lower RALAT benefits:
#a. better operation at low frequency, for LPDDR2 freq < 100MHz, change RALAT to 3
#b. Small performence improvment
monitor memU32 0x021b0018 = 0x00001740 # MMDC0_MDMISC
monitor memU32 0x021b001c = 0x00008000 MMDC0_MDSCR, set the Configuration request bit during MMDC set up
monitor memU32 0x021b002c = 0x000026D2 # MMDC0_MDRWD
monitor memU32 0x021b0030 = 0x00431023 # MMDC0_MDOR
monitor memU32 0x021b0040 = 0x00000017 # Chan0 CS0_END
monitor memU32 0x021b0000 = 0x83190000 # MMDC0_MDCTL
#Mode register writes
monitor memU32 0x021b001c = 0x04008032 # MMDC0_MDSCR, MR2 write, CS0
monitor memU32 0x021b001c = 0x00008033 # MMDC0_MDSCR, MR3 write, CS0
monitor memU32 0x021b001c = 0x00048031 # MMDC0_MDSCR, MR1 write, CS0
monitor memU32 0x021b001c = 0x05208030 # MMDC0_MDSCR, MR0write, CS0
monitor memU32 0x021b001c = 0x04008040 # MMDC0_MDSCR, ZQ calibration command sent to device on CS0
monitor memU32 0x021b0020 = 0x00005800 # MMDC0_MDREF
monitor memU32 0x021b0818 = 0x00011117 # DDR_PHY_P0_MPODTCTRL
monitor memU32 0x021b0004 = 0x0002556D # MMDC0_MDPDC now SDCTL power down enabled
monitor memU32 0x021b0404 = 0x00011006 # MMDC0_MAPSR ADOPT power down enabled, MMDC will enter automatically to self-refresh while the number of idle cycle reached.
monitor memU32 0x021b001c = 0x00000000 # MMDC0_MDSCR, clear this register (especially the configuration bit as initialization is complete)
monitor memU32 0x020e0010 = 0xF00000CF # enable AXI cache for VDOA/VPU/IPU
monitor memU32 0x020e0018 = 0x007F007F # set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7
monitor memU32 0x020e001c = 0x007F007F # set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7
load u-boot
cont
davidziv
#monitor speed auto
monitor reset
monitor halt
monitor sleep 1000
# Disable WDOG
# IOMUX
#DDR IO TYPE:
#CLOCK:
#ADDRESS:
#Control:
#Data Strobes:
#Data:
# Row address:     15
# Data bus width 32
#Read calibration
#Write calibration
#MMDC init:
load u-boot
cont
Hi David
one can look at
https://community.freescale.com/thread/376786
http://forum.segger.com/index.php?page=Thread&threadID=1550
http://forum.segger.com/index.php?page=Thread&threadID=1995
some jtag init scripts can be found in /tools folder of
"MX6_PLATFORM_SDK "
https://community.freescale.com/docs/DOC-94139
davidziv
I have used this script to initialize IMX6
#monitor speed auto
monitor reset
monitor halt
monitor sleep 1000
# Disable WDOG
monitor memU32 0x020c4068 = 0xffffffff
monitor memU32 0x020c406c = 0xffffffff
monitor memU32 0x020c4070 = 0xffffffff
monitor memU32 0x020c4074 = 0xffffffff
monitor memU32 0x020c4078 = 0xffffffff
monitor memU32 0x020c407c = 0xffffffff
monitor memU32 0x020c4080 = 0xffffffff
# IOMUX
#DDR IO TYPE:
#CLOCK:
#ADDRESS:
#Control:
#Data Strobes:
#Data:
# Row address:     15
# Data bus width 32
monitor memU32 0x021b080c  = 0x0045004B
monitor memU32 0x021b0810 = 0x00240027
monitor memU32 0x021b083c = 0x0238023C # MPDGCTRL0 PHY0
monitor memU32 0x021b0840 = 0x020C0214 # MPDGCTRL1 PHY0
#Read calibration
monitor memU32 0x021b0848 = 0x44464848 # MPRDDLCTL PHY0
#Write calibration
monitor memU32 0x021b0850 = 0x38342C32 # MPWRDLCTL PHY0
#MMDC init:
monitor memU32 0x021b0008 = 0x00333040 # MMDC0_MDOTC
monitor memU32 0x021b000c = 0x676B52F3 # MMDC0_MDCFG0
monitor memU32 0x021b0018 = 0x00011740 # MMDC0_MDMISC
monitor memU32 0x021b0030 = 0x006B1023 # MMDC0_MDOR
monitor memU32 0x021b0040 = 0x0000001F # Chan0 CS0_END
monitor memU32 0x021b0000 = 0x84190000 # MMDC0_MDCTL
monitor memU32 0x021b001c = 0x02008032 # MMDC0_MDSCR, MR2 write, CS0
monitor memU32 0x021b0020 = 0x00007800 # MMDC0_MDREF
monitor memU32 0x021b0818 = 0x00022227 # DDR_PHY_P0_MPODTCTRL
#UART PORT INIT
monitor memU32 0x020e0050 = 3 #
monitor memU32 0x020e004c = 3 #
monitor memU32 0x020308fc = 3 #
Then I load the uboot
load u-boot
For some reason it doesn't start
David.
