I am using MQX_Lite on a FRDM-KE06Z dev board, and when I try to create a lwevent group at the beginning of a task, the Unhandled_ivINT_Hard_Fault ISR is called. I have lwevents enabled in the MQX_Lite PEx Component, but is there something else that I need to include to be able to use them?
Hello Zachary Walton:
Could you tell me what software (CodeWarrior, KDS, PE Driver Suite) and the version you are using?
For example I tried to create a MQX Lite project in CodeWarrior v10.6 for the KE06 and I did not see a hardfault when creating a LWEVENT. That is why I need more information to replicate the issue and report it to developers.
Thank you!
Jorge Gonzalez
