I have looked on the Freescale website for information on power supply and I/O recommendations for the MPC5634M, without success.
Can anyone help with this information. I am new to the MPC5634M and want to get my design correct.
Ray.
Solved! Go to Solution.
Hi Ray,
Unfortunately we do not have a specific hardware design guide for the MPC5634M device. I could recommend you some general or MPC55xx appnotes that could be useful, but at first try to look to the datasheet:
Datasheet:
http://cache.freescale.com/files/32bit/doc/data_sheet/MPC5634M.pdf?fsrch=1&sr=1&pageNum=1
AN3254 - Power Supplies on the MPC5500:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN3254.pdf
AN3208 - Crystal Oscillator Troubleshooting Guide:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN3208.pdf
AN1706 - Microcontroller Oscillator Circuit Design Considerations:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN1706.pdf
AN1259 - System Design and Layout Techniques for Noise Reduction:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN1259.pdf
AN2706 - EMC Guidelines for MPC5500-Based Systems:
http://cache.freescale.com/files/32bit/doc/app_note/AN2706.pdf
AN2705 - Signal Integrity Considerations with MPC5500-based systems:
http://cache.freescale.com/files/32bit/doc/app_note/AN2705.pdf
AN2127 - EMC Guidelines for MPC Based Automotive Powertrain Systems:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN2127.pdf
Martin
Hi Ray,
Datasheet:
Martin
Martin,
Thank you.
Ray.
