i.MX6 Linux BSP supported display resolution.
satoshishimoda
Senior Contributor I
Hi community,
We have a question about i.MX6 Linux BSP (L3.14.28).
I want to know the supported display resolution by L3.14.28.
What file should I read to check the supported resolution?
I found drivers/video/modedb.c, is this the one? or other file?
Satoshi Shimoda
Yuri
Your understanding is right regarding " $ cat /sys/class/graphics/fbx/mode   // current activated resolution ".
As for "  $ cat /sys/class/graphics/fbx/modes " - it provides all supported (in current BSP realization)
modes.
Yuri.
Yuri
To check supported modes please use the next Linux command :
$ cat /sys/class/graphics/fb0/modes
To define current mode  :
Yuri
satoshishimoda
Hi Yuri,
Thank you for your prompt reply.
I executed the above commands, but I felt the commands do not show all the resolution.
I think the commands are as below, right?
$ cat /sys/class/graphics/fbx/modes  // current assigned resolution
I want to know all the supported resolution that I can use without any source code modification.
For example, I did not get 800x480@60 by the above commands, but BSP supports this resolution since it supports CLAA-WVGA display.
Satoshi Shimoda
Yuri
modes.
Yuri.
