I guess the title says it all. :smileyhappy:
I can certainly do the investigative work to track which LW Semaphore is getting blocked by looking for sequential calls to OSA_SemaWait, but since the MQX task-aware debugging plugin can tell me that a task is stuck waiting on a blocked LW semaphore, why doesn't it tell me which one? It would be such a time saver!!!
Hi Dave
I tested the demo C:\Freescale\Freescale_MQX_4_1\mqx\examples\lwsem, as you said, I can see that one task is stuck waiting on a blocked lw semaphore.
I think it is a good idea to show the blocked semaphore.
But when you show the light weight semaphores, you can know the waiting semaphore, see the below picture.
danielchen@fsl I was wrong! I get a "Not installed" message when I check the LW message queue and LW semaphore windows. Do you have any suggestions for what I can do to install them?
What's interesting is that I'm debugging another project at the moment, and now I do have Lightweight Semaphores enabled:
But now the annoying thing is that I have a problem where lwIP is blocked in a LW message queue, but as you can see in the image above, I can't view the message queues!
Does anyone have any suggestions about this?
Thanks, Daniel! I could have sworn that the last time I looked at that screen, the Symbol column was entirely empty. I'll check it again the next time I get stuck! :smileyhappy:
