Freescale's eSDHC - Does it work with "regular" SD devices?
habibbaydoun
I am trying to interface to a LAIRD wifi board that using the standard connections: 4 data lines, 1 cmd line, 1 clk.  I am assuming I would simply not use the extra lines from eSDHC...would I be correct?
The wifi board is an SSD45N from Laird Tech.
Thank you!
