MMA8452Q PCB layout suggestions
martincoster
Attached image of my MMA8452Q PCB layout. Any comments on the design? The data sheet says I should provide dangling tracks for unused pins, to reduce stress during reflow. Also kept any via's >2mm away from chip as per data sheet, and no ground plane below chip. Our application is very basic, I will just pole the chip for data once a second. I do not need interrupts. Any comments appreciated.
reyes
Hi Martin,
I just checked the part of the layout you sent and everything seems to be correct, you should not get any problem related with the layout of the MMA8452Q.
Jose Reyes
reyes
Hi Martin,
Jose Reyes
martincoster
Thanks!
Martin
