my pc is 64 bit,i am installed codewarrior 10.6v,shows error rxtx library not installed
Solved! Go to Solution.
CW for MCU v10.6 can support 64bit win7/win8 without problem.
did you choose full install during install CW?
can you please send us the screenshot of the problem?
Zhang Jun
Zhang Jun
Hi Dhanalakshmi
Please install the RXTX for Eclipse in CodeWarrior IDE from <Help> menu-> Install New Software…, then add Site and install from: http://rxtx.qbang.org/eclipse/
Does it help?
Fiona Kuang
Technical Information & Commercial Support
