sockutil and sock_util, RTCS/MQX4.1 to MQX4.2
pmt
Contributor V
I am porting a project (Keil uV tools) from MQX 4.1 to MQX4.2 and I get this curious linking error:
linking...
.\IntFlashDebug\Phd.axf: Error: L6200E: Symbol SOCK_Add_owner multiply defined (by sock_util.o and sockutil.o).
.\IntFlashDebug\Phd.axf: Error: L6200E: Symbol SOCK_Free_sock_struct multiply defined (by sock_util.o and sockutil.o).
.\IntFlashDebug\Phd.axf: Error: L6200E: Symbol SOCK_Get_sock_struct multiply defined (by sock_util.o and sockutil.o).
.\IntFlashDebug\Phd.axf: Error: L6200E: Symbol SOCK_Is_owner multiply defined (by sock_util.o and sockutil.o).
.\IntFlashDebug\Phd.axf: Error: L6200E: Symbol SOCK_Remove_owner multiply defined (by sock_util.o and sockutil.o).
.\IntFlashDebug\Phd.axf: Error: L6200E: Symbol SOCK_check_valid multiply defined (by sock_util.o and sdgram.o).
Not enough information to list image symbols.
What is the deal with 'sock_util'?  Should I be removing it from the RTCS library build?  Is this a legacy support thing?
pmt
Contributor V
O.K. I answered my own question.  I had a library setup issue in the project.  I was crossing 4.2 and 4.1 library paths.  Setup is now resolved.
pmt
Contributor V
soledad
Thanks for your input
