Hi.
We have purchased a CW10.6 KinetisMCU 2-user floating license. Now we have two separate locations working on the same project. Can we easily split the license into 2x single-user floating licenses (preferrably), or do we have to convert it to 2 node-locked licenses?
I've found the registration in our data base.
I think the best way is to use 2 registrations.
I will provide you a new registration code and change to 1 user the current floating license file.
I will create a SR and will contact you directly.
Pascal
Freescale Technical Support
