Dear all,
I met a problem about the 3g and wifi switch.
My devices support 3G and wifi,when I turn on the WIFI,it device can turn off the 3g automatic,but,
when I turn off the WIFI,the 3G cannot turn on again.
I had catched these logs,please see the attachment files.
Can anyone know how to solve this problem?
BTW,
1.my BSP version is android4.4.2+imx6sl evk;
2.the 3G type is CDMA.
Thanks very much.
Original Attachment has been moved to: 3g_radio_log.log.zip
Original Attachment has been moved to: system_logcat.log.zip
As far as I can see from reading the logs, most likely this is the issue of the
CDMA modem driver that is unable to bring the modem back up correctly after
suspending it. Ask the modem vendor for that.
Artur
