When will the FRDM-KE02Z40M development board be supported by the SDK?
richbayless
Similar to other questions from other people, I'm wondering when the SDK will support the KE02 MCU development board?  Thanks,  Rich.
Tags (2)
ivadorazinova
Hello Rich,
no, there is no support for this MCU by KSDK,
but you can take another project, modified it and it could work.
Iva
ivadorazinova
Hello Rich,
Iva
grzegorzkonopko
Hi Iva
Is such guide already available?
Best Regards
/GReg
ivadorazinova
Hi Grzegorz,
unfortunately not. Because they are 5V and the peripherals are so different with other Kinetis Families.
This is also reason, why KE/KEA will not be supported by KSDK.
I apologize for the inconvenience that caused you.
Have a nice day,
Iva
grzegorzkonopko
Hi Iva
1. Is such difference describe, any document?
2. does such difference cause any sides if we I want to use KDS and Processor Expert?
/Greg
richbayless
We have been successfully using KDS and Processor Expert with the KE and the KEA development boards, as follows:
FRDM-KE02Z40M
TRK-KEA64
FRDM-KEAZ64Q64
Rich.
ivadorazinova
I apologize for my late response, I don´t see this update.
You can take a look at Reference Manual and Datasheet for KE Family and compare with others.
Also you can use the tool Product Selector
Processor Expert supports KE/KEA family, please see PEx for Kinetis 3.0.1 Release Note
I hope this helps.
Iva
richbayless
Hello Iva,
Great, I look forward to using the guide!
Thanks,  Rich.
