K64 Jump to App
K64 Jump to App
Mike_d
I'm having a hard time getting an MQX app to run from address 0x15000.  I have updated the linker so it builds in that space and set MQX_ROM_VECTROS to false.  I should be able to get it to run if I stop at program entry point and do a "move to" at address 0x15000 in Disassembly right?  I end up with an unhanded exception.
soledad
Hello Michael,
Please check the below thread and let me know if this helps.
MQX memory usage
Sol
Mike_d
It's getting stuck on the following lines with the K64.  Works fine on the K60.
WDOG_UNLOCK = (uint16_t)STARTUP_WDOG_KEY_1; /* Key 1 */
WDOG_UNLOCK = (uint16_t)STARTUP_WDOG_KEY_2; /* Key 2 */
