Dear All,
I used MicroSD to Use android 4.4.2 is OK, but i try to use eMMC is wrong.
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
healthd: BatteryHealthPath not found
init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
init: property 'ro.serialno' doesn't exist while expanding '$ro.serialno'
init: cannot expand '$ro.serialno' while writing to '/sys/class/android_usb/android0/iSerial'
init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
healthd: BatteryPresentPath not found
healthd: BatteryCapacityPath not found
healthd: BatteryVoltagePath not found
healthd: BatteryTemperaturePath not found
healthd: BatteryTechnologyPath not found
binder: 2271:2271 transaction failed 29189, size 0-0
init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
init: powerctl: cannot expand '${sys.powerctl}'
init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
request_suspend_state: wakeup (3->0) at 12110443336 (2015-10-11 00:12:34.620492335 UTC)
request_suspend_state: wakeup (0->0) at 12110443336 (2015-10-11 00:12:34.620492335 UTC) <===always repeat!!!
" ANDROID" <=====smoothly and stop on this word.
what can i do for this issue???
Hi alex
how did you program image to emmc ? Had you used mfg tools for android 4.4.2
i.MX 6Family Manufacturing Toolkit for kk4.4.2_1.0.0
SABRE Board Reference Design|Freescale
and followed procedure given in sect. sect.3.3 Downloading board images
attached Android_Quick_Start_Guide.pdf
