some question for porting wm8960 to yocto 1.6.2
Question asked by ChuYuan Chiang on Sep 20, 2015
Latest reply on Sep 20, 2015 by Yuri Muhin
ChuYuan Chiang asked4 days ago
I found this url Porting WM8960 to Android jb4.2.2  about porting the wm8960 in android (kernel version is 3.0.35)
but in yocto 1.6.2 that is using device tree and 3.10.53 kernel.
I try port it, but the AUD3_TXD still not output any signal.
the following is my device tree for sound part:
sound {
compatible = "fsl,imx-audio-wm8960";
model = "wm8960-audio";
cpu-dai = <&ssi2>;
audio-codec = <&codec>;
codec-master;
gpr = <&gpr>;
audio-routing =
"Headset Jack", "HP_L",
"Headset Jack", "HP_R",
"Ext Spk", "SPK_LP",
"Ext Spk", "SPK_LN",
"Ext Spk", "SPK_RP",
"Ext Spk", "SPK_RN";
hp-det = <3 1>;
hp-det-gpios = <&gpio7 8 0>;
mic-det-gpios = <&gpio1 9 0>;
codec: wm8960@1a {
compatible = "wlf,wm8960";
reg = <0x1a>;
status = "okay";
clocks = <&clks 201>;
clock-names = "mclk";
wlf,shared-lrclk;
&audmux {
  pinctrl-names = "default";
  pinctrl-0 = <&pinctrl_audmux_wcp>;
  status = "okay";
  ssi2 {
  fsl,audmux-port = <MX31_AUDMUX_PORT2_SSI1>;
  fsl,port-config = <
  (IMX_AUDMUX_V2_PTCR_TFSDIR |
  IMX_AUDMUX_V2_PTCR_SYN |
  IMX_AUDMUX_V2_PTCR_TFSEL(MX31_AUDMUX_PORT3_SSI_PINS_3) |
  IMX_AUDMUX_V2_PTCR_TCLKDIR |
  IMX_AUDMUX_V2_PTCR_TCSEL(MX31_AUDMUX_PORT3_SSI_PINS_3))
  IMX_AUDMUX_V2_PDCR_RXDSEL(MX31_AUDMUX_PORT3_SSI_PINS_3)
  aud3 {
  fsl,audmux-port = <MX31_AUDMUX_PORT3_SSI_PINS_3>;
  fsl,port-config = <
  IMX_AUDMUX_V2_PDCR_RXDSEL(MX31_AUDMUX_PORT2_SSI1)
Dose any one have idea about this?
ChuYuan
