Calculating Vybrid CPU core temperature with the internal temperature sensor
Question asked by Bhuvanchandra DV on Sep 17, 2015
Latest reply on Sep 23, 2015 by jiri-b36968
Hi!
At the moment the internal temperature sensor readings are calculated using the formula[ Temp = 25 - ( (Vtemp -Vtemp25) / m) ]
with optimal slope-coefficient constant at all temperatures provided in Vybrid datasheet, we observe a difference of ~20 'C from
the internal temperature reading and the external temperature on SoC package. We believe there could not be much temperature
differnce. When using the cold/hot slope-coefficients constants provided in AN3031[1] there is ~4'C difference between the internal
cpu temperature and the external temperature on SoC package. Can some one please confirm the temperature difference between
the internal CPU core and the external SoC temperature on package.
[1] https://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CBwQFjAAahUKEwjW-amA1f_HAhXLppQKHa…
Bhuvan
