when we flash SW using Mfgtool "format disc popup" will appear (discarding popup as it does not affect any functionality).
Is there any way we can fix in OS side to disable popup as Mfgtool uses UTP protocol to transfer images i am not sure fixing that in OS side may have side effects
Is there any proven solution available?
Ashok
Actually, this is not the MFGtool pop-up but the OS pop-up. It occurs at the moment when target board switches from emulating USB HID device to USB Mass-storage device. Typically, it occurs on slowly-running host OSes. Try to do it on a faster machine :-)
Artur
