Henry Jacobs
Need bootloader for QE128(flexis)
Discussion created by Henry Jacobs on Jan 24, 2008
Latest reply on Jan 4, 2016 by Stan Ivanov
I am porting an application from HCS08 to QE128 processor and have not found bootloader for QE128(flexis) processor.
The QE128 does not seem to support interrup vector redirection, although the interrupt vectors appear to be write protected whenever any Flash memory is protected.
Work-arounds appear to be:
1) Unprotect bootloader code (not desirable)
2) Create dummy ISRs that do re-direction to actual ISR
Has anyone done a bootloader for the QE128?
