Baremetal sdk for i.MX6Solox Sabre Board Smart Devices
kennethyu
I'm interested in porting the "imx6_platform_sdk_v1.1.0" to the "Sabre Board for Smart Devices Based on the I.MX6SoloX".
Has anyone done this before?
Any guidance would be much appreciated.
Thank-you in advance for your help
Kenneth
kennethyu
Igor,
Thank-you for your quick response.
The link to "MX6 SoloX bare metal startup" was very helpful.
Now, I'm trying to run the MX6SX_hello_MFG provided in "MX6 SoloX bare metal startup".
But when I use the MFGTool2, I get the following error:
Can you please tell me what I am doing wrong?
Is the MfgTool trying to write to the SDcard which I do have one on the SD4 slot?
Thank-you in advance for your help.
Kenneth
Hi Kenneth
I am not aware of SDK for I.MX6SoloX, but most of SDK tests
should work OK with SoloX, since it shares similar IP modules with
other i.MX6 processors. One can use init codes and jtag configuration
given on link below
kennethyu
Igor,
Kenneth
Hi Kenneth
I would suggest to create new thread for this problem.
kennethyu
Hi Igor,
Yes, will do.
Thank-you again for your help.
Kenneth
