Hi everyone,
Does anyone know if Kinetis SDK 3.0 has a log file, GUI, console configuration that tell you what your
code size is? How much is actually going to the processor? If it doesn't have a feature that displays
this information, then how can I go about at least estimating how much code, between the SDK and
what I have written?
Neil
Solved! Go to Solution.
Hello Neil,
Please enable the "Print size" :
then build your project , you can see the code size on the "Console " window :
Hope it helps
Alice
Hello Neil,
Hope it helps
Alice
Hi Neil,
in addition to what Alice has provided:
I hope this helps,
Erich
Thank you Alice!
