how to yocto on imx6sxsabresd
x10
Contributor V
Hi, All
Try to use Freescale Yocto Project on imx6sx-SDB,and following <Freescale Yocto Project User's Guide>, but fail to see imx6sxsabresd with "source setup-environment". What should I do to setup proper environment for developing imx6sx. Thanks!
zhl-ce8@ubuntu:~/fsl-release-bsp$ source setup-environment
Usage: source setup-environment <build-dir>
    <build-dir>: specifies the build directory location (required)
If undefined, this script will set $MACHINE to 'imx6qsabresd'.
Supported machines:
  imx23evk
  imx28evk
  imx31pdk
  imx35pdk
  imx51evk
  imx53ard
  imx53qsb
  imx6dlsabreauto
  imx6dlsabresd
  imx6qsabreauto
  imx6qsabresd
  imx6slevk
  imx6solosabreauto
  imx6solosabresd
  ls1021aqds
  ls1021atwr
  twr-vf65gs10
  cfa10036
  cfa10037
  cfa10049
  cfa10055
  cfa10056
  cfa10057
  cfa10058
  cgtqmx6
  cubox-i
  imx233-olinuxino-maxi
  imx233-olinuxino-micro
  imx233-olinuxino-mini
  imx233-olinuxino-nano
  imx6dl-riotboard
  imx6qsabrelite
  m28evk
  m53evk
  nitrogen6x
  nitrogen6x-lite
  pcl052
  pcm052
  quartz
  wandboard-dual
  wandboard-quad
  wandboard-solo
To build for a machine listed above, run this script as:
MACHINE=<machine> source setup-environment <build-dir>
Cheng Shi
emtronix
Labels (3)
BiyongSUN
