1. Kindly help how to start working on BootLoader.
The RAppID Bootloader installation folder contains the RAppID Bootloadr User manual. This gives you all you need to use it.
Moreover on the FSL web you can find some other documents dealing with RAppID Bootloader usage. For example
Overview of RAppID Bootloader:
http://www.freescale.com/training/online-academy/overview-of-rappid-bootloader:WBNR_FTF2014-AUT-F0014-B
How to Use Boot Assist Module (BAM) on TWR-PXS20 Board:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4546.pdf
BR,
Petr
Yes,
I knew it,
but only thing is how to start writing flash driver code..
and I need some help on how to write code for Boot Application Algorithm etc., codes.
Please Help me.
I didn't understand the documents supplied, because I am new to Boot-loader Implementation.
BR,
Petr
