KDS 3.0 startup error screen
Question asked by Neil Porven on Sep 12, 2015
Latest reply on Sep 13, 2015 by Neil Porven
Hi everyone,
I starting this discussion because I have been noticing this window that appears when the IDE is starting.
First let me show you the window that appears before the error (this is normal behavior)
Now, once I click on OK the following window shows.  Unfortunately its very light in the following picture
but, it actually shows clear and it last about 5 to 8 seconds, then it disappears after Kinetis loads up.
It reads,
Restoring Problems
Unable to restore to working set state
then it gives the option to hit OK or Details, but when you click on either one, the window reads not responding.
Do I have to re-install the Kinetis 3.0 or is there a fix/patch to this issue?
Neil
