I just bough a FRDM-K22F dev kit, download Kinetics design studio, update and install all I founded, patch the app as I saw here https://community.freescale.com/thread/363937 (I had same problem).
Now, I just import one of the examples and I had a bunch of problems with path definitions, the app doesn't found sources and includes, twice worst if I import and copy the project in my workspace.
Watch the path "C:/platform", the SDK and all is installed and running, beacuse I make run and debug some basic programs, and now I need the examples.
Pleas someone enlight me, I'm testing this for a new device that I have to develop, but I only have experience with Atmel, TI and PIC microcontrollers and I really want to make run my dev in this plataform.
JPCE
Hi Juan,
you have incorrectly set paths for the project.
Please, can you check KSDK_PATH in Environment Variables?
Please, take a look at No rule to make target | MCU on Eclipse
Let us know, if it helps you.
Iva
Indeed, environment variables are not set :/
Is that a installer bug ?, or I suppose to know that ?
There must be set paths.
Yes, it could be, please try uninstall KSDK and install again.
Iva
I did it and doesn't work.
What else can I do.
btw, I just update windows to windows 10 before install kinetics design studio.
JPCE
I uninstall all and install again, and didn't work.
I tried tu put by hand the paths and same problems awnyway.
Now I'm trying to update the paths one by one, long boring task... and I have this problem:
complain about definitions/declarations that should be able to handle, and yes, I clean project, refresh, recompile, etc...
JP
Hi Juan,
Please, can you attach your project? It could be incorrect setting for the toolchain in your project.
Iva
