About the PCB pad diameter size for i.MX6SoloLite(0.5mm pitch)
yuuki
Senior Contributor II
Dear all,
Could you tell me PCB pad diameter size(pad mask size) for i.MX6SoloLite.
I found the following URL.
https://community.freescale.com/message/459436#459436
I want similar information about i.MX6SoloLite(0.5mm pitch).
yuuki
Tags (3)
Yongxin
Hi Yuuki,
The PCB pad diameter of i.MX6SL (0.5mm pitch) is 0.3mm. Please see the detail information in Section 4.2.1Pad Diameter in AN4982 in the following link,
http://cache.freescale.com/files/analog/doc/app_note/AN4982.pdf
Yongxin
Yongxin
Hi Yuuki,
Yongxin
