Boot time too long and Usb detection problem
Question asked by Aida Meriem on Sep 7, 2015
Latest reply on Sep 8, 2015 by Aida Meriem
Hi everyone,
I'm having some problems with my imx28 (again ^^).
1- The first problem is the boot time. I'm around 25 seconds and I need to achieve less then 4 seconds. Here's my boot log :
[    0.000000] Linux version 4.0.4-fslc+g48548f7 (user@adress) (gcc version 4.9.2 (GCC) ) #1 Mon Sep 7 10:23:51 UTC 2015
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[    0.000000] CPU: VIVT data cache, VIVT instruction cache
[    0.000000] Machine model: Freescale i.MX28 Evaluation Kit
[    0.000000] Memory policy: Data cache writeback
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: console=ttyAMA0,115200 root=/dev/mmcblk0p3 rw rootwait
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Memory: 113928K/131072K available (5111K kernel code, 281K rwdata, 2020K rodata, 248K init, 8170K bss, 17144K reserved, 0K cma-reserv)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc06ff038   (7133 kB)
[    0.000000]       .init : 0xc0700000 - 0xc073e000   ( 248 kB)
[    0.000000]       .data : 0xc073e000 - 0xc0784500   ( 282 kB)
[    0.000000]        .bss : 0xc0784500 - 0xc0f7ed48   (8171 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000048] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
[    0.001892] Console: colour dummy device 80x30
[    0.002066] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[    0.002099] ... MAX_LOCKDEP_SUBCLASSES:  8
[    0.002124] ... MAX_LOCK_DEPTH:          48
[    0.002147] ... MAX_LOCKDEP_KEYS:        8191
[    0.002168] ... CLASSHASH_SIZE:          4096
[    0.002190] ... MAX_LOCKDEP_ENTRIES:     32768
[    0.002212] ... MAX_LOCKDEP_CHAINS:      65536
[    0.002233] ... CHAINHASH_SIZE:          32768
[    0.002255]  memory used by lock dependency info: 5167 kB
[    0.002277]  per task-struct memory footprint: 1152 bytes
[    0.002415] Calibrating delay loop... 226.09 BogoMIPS (lpj=1130496)
[    0.071252] pid_max: default: 32768 minimum: 301
[    0.071945] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072015] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.079302] CPU: Testing write buffer coherency: ok
[    0.083187] Setting up static identity map for 0x404dcc10 - 0x404dcc68
[    0.098305] devtmpfs: initialized
[    0.106765] pinctrl core: initialized pinctrl subsystem
[    0.184628] NET: Registered protocol family 16
[    0.187091] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.302841] Serial: AMBA PL011 UART driver
[    0.305705] 80074000.serial: ttyAMA0 at MMIO 0x80074000 (irq = 234, base_baud = 0) is a PL011 rev2
[    0.590527] console [ttyAMA0] enabled
[    0.669181] mxs-dma 80004000.dma-apbh: initialized
[    0.688880] mxs-dma 80024000.dma-apbx: initialized
[    0.713411] SCSI subsystem initialized
[    0.719913] usbcore: registered new interface driver usbfs
[    0.726020] usbcore: registered new interface driver hub
[    0.732111] usbcore: registered new device driver usb
[    0.746103] pps_core: LinuxPPS API ver. 1 registered
[    0.751121] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.760637] PTP clock support registered
[    0.767724] Advanced Linux Sound Architecture Driver Initialized.
[    0.781838] Switched to clocksource mxs_timer
[    1.165139] NET: Registered protocol family 2
[    1.174744] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    1.182281] TCP bind hash table entries: 1024 (order: 3, 36864 bytes)
[    1.189684] TCP: Hash tables configured (established 1024 bind 1024)
[    1.197816] TCP: reno registered
[    1.201165] UDP hash table entries: 256 (order: 2, 20480 bytes)
[    1.207769] UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
[    1.216617] NET: Registered protocol family 1
[    1.224600] RPC: Registered named UNIX socket transport module.
[    1.230590] RPC: Registered udp transport module.
[    1.235475] RPC: Registered tcp transport module.
[    1.240231] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.256496] futex hash table entries: 256 (order: 1, 11264 bytes)
[    1.381170] NFS: Registering the id_resolver key type
[    1.387577] Key type id_resolver registered
[    1.391959] Key type id_legacy registered
[    1.396726] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[    1.421463] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.429777] io scheduler noop registered (default)
[    1.441133] backlight supply power not found, using dummy regulator
[    1.485549] Console: switching to colour frame buffer device 100x30
[    1.508979] mxsfb 80030000.lcdif: initialized
[    2.122211] uart-pl011 80074000.serial: no DMA platform data
[    2.129937] 80070000.serial: ttyAPP3 at MMIO 0x80070000 (irq = 233, base_baud = 1500000) is a 80070000.serial
[    2.142922] mxs-auart 80070000.serial: Found APPUART 3.1.0
[    2.149908] at24 0-0051: 4096 byte 24c32 EEPROM, writable, 32 bytes/write
[    2.193404] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xf1
[    2.199815] nand: Micron MT29F1G08ABAEAWP
[    2.203968] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    2.211980] Scanning device for bad blocks
[    2.691187] gpmi-nand 8000c000.gpmi-nand: driver registered.
[    2.835389] libphy: fec_enet_mii_bus: probed
[    2.845966] 800f4000.ethernet supply phy not found, using dummy regulator
[    2.860471] usbcore: registered new interface driver asix
[    2.866881] usbcore: registered new interface driver ax88179_178a
[    2.873645] usbcore: registered new interface driver cdc_ether
[    2.880161] usbcore: registered new interface driver smsc95xx
[    2.886565] usbcore: registered new interface driver net1080
[    2.892879] usbcore: registered new interface driver cdc_subset
[    2.899314] usbcore: registered new interface driver zaurus
[    2.905875] usbcore: registered new interface driver cdc_ncm
[    2.911627] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.919037] usbcore: registered new interface driver usb-storage
[    2.952396] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    2.958265] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    2.982163] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    3.002985] hub 1-0:1.0: USB hub found
[    3.007308] hub 1-0:1.0: 1 port detected
[    3.025872] mousedev: PS/2 mouse device common for all mice
[    3.037749] stmp3xxx-rtc 80056000.rtc: rtc core: registered 80056000.rtc as rtc0
[    3.047002] i2c /dev entries driver
[    3.061431] stmp3xxx_rtc_wdt stmp3xxx_rtc_wdt: initialized watchdog with heartbeat 19s
[    3.070176] Driver 'mmcblk' needs updating - please use bus_type methods
[    3.080625] mxs-mmc 80010000.ssp: Got WP GPIO
[    3.122149] mxs-mmc 80010000.ssp: initialized
[    3.157460] usbcore: registered new interface driver usbhid
[    3.163249] usbhid: USB HID core driver
[    3.177558] input: mxs-lradc as /devices/soc0/80000000.apb/80040000.apbx/80050000.lradc/input/input0
[    3.212743] sgtl5000 0-000a: Failed to get mclock: -517
[    3.219947] i2c 0-000a: Driver sgtl5000 requests probe deferral
[    3.234314] mxs-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[    3.241276] mxs-sgtl5000 sound: snd_soc_register_card failed (-517)
[    3.248115] platform sound: Driver mxs-sgtl5000 requests probe deferral
[    3.256465] TCP: cubic registered
[    3.259904] NET: Registered protocol family 17
[    3.265953] Key type dns_resolver registered
[    3.280727] registered taskstats version 1
[    3.288902] mmc0: new high speed SDHC card at address e624
[    3.308456] sgtl5000 0-000a: sgtl5000 revision 0x11
[    3.314644] mmcblk0: mmc0:e624 SS04G 3.69 GiB
[    3.348697]  mmcblk0: p1 p2 p3
[    3.369576] sgtl5000 0-000a: Using internal LDO instead of VDDD
[    3.398503] mxs-sgtl5000 sound: sgtl5000 <-> 80042000.saif mapping ok
[    3.407194] mxs-sgtl5000 sound: sgtl5000 <-> 80046000.saif mapping ok
[    3.435091] stmp3xxx-rtc 80056000.rtc: setting system clock to 2015-09-07 11:02:28 UTC (1441623748)
[    3.486099] can-3v3: disabling
[    3.489251] usb0_vbus: disabling
[    3.493076] ALSA device list:
[    3.496093]   #0: mxs_sgtl5000
�[    3.522333] kjournald starting.  Commit interval 5 seconds
[    3.533060] EXT3-fs (mmcblk0p3): using internal journal
[    3.538354] EXT3-fs (mmcblk0p3): mounted filesystem with ordered data mode
[    3.545725] VFS: Mounted root (ext3 filesystem) on device 179:3.
[    3.557450] devtmpfs: mounted
[    3.562637] Freeing unused kernel memory: 248K (c0700000 - c073e000)
INIT: version 2.88 booting
Starting udev
[    6.127034] udevd[77]: starting version 182
[    9.355162] random: dd urandom read with 79 bits of entropy available
INIT: Entering runlevel: 5
Configuring network interfaces... [   11.527838] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0)
udhcpc (v1.23.2) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
done.
Starting syslogd/klogd: done
The red text takes most of the boot time. It seems to be a udev and a network issue. I don't need a network interface or the eth0 driver.
Any Idea about how to fix the udev start ? Maybe it's related to the device tree ? And how to remove the configuring network interface from tho boot routine ?
2- I'm trying to use a GSM board with the USB interface of the IMX. The problem is that when I plug the GSM board on the "Usb host" of the imx, I receive the message :
usb 1-1: new high-speed USB device number 0 using ci_hdrc
root@vubox-mockup:/dev# lsusb
Bus 001 Device 004: ID 1519:0020 Comneon HSIC Device
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
But there's nothing on /dev/ttyUSBx. And when I lunch "top", I find a "/dev/udev" process going on. Again, it may be related to the device tree ?
I don't know if the long time taken by udev to start is directly connected to the USB issue but, I do need to find my GSM board on /dev/ttyUSBx and to boot in less then 4 seconds...
Thank you !
NB : Here the USB driver of my GSM board Sierra Wireless - Support Center
And a documentation : AirPrime_HL_Series_Development_Kit AirPrime HL 8548
NB2: I'm using Yocto :-)
